| Posted by hj on April 06, 2002 at 11:17:16: | |
| In response to Re: toilet has risen off of floor | |
From your description, you that may just be the symptom of a larger problem. Apparently the floor has settled and the toilet is now sitting on the flange that was originally on the floor. You have to determine what is moved and correct that if possible, otherwise you will have to remove the toilet and cut off the pipe and redo the connection. : I have a Log home and my toilet has risen off of the floor and rocks. I have placed a piece of wood under the base to keep it from rocking but I don't know where to start to solve the problem. Help!
