| Posted by hj on April 04, 2002 at 23:19:43: | |
| In response to Re: CAST PIPE FITTINGS | |
About the only way other than cutting the fitting out, is to use the same tool that was used to assemble them. Without it you cannot grip the fitting and also pull it out. : TRYING TO REPLACE 1) A 2" Y AND 2) A 3" 90. BOTH INSTALLED WITH RUBBER GASKETS, ABOUT 1969. SATURATED WITH WD40 AND LPS1. UNABLE TO PULL FITTINGS FROM PIPE. ABLE TO TURN ONLY. HAVE BROKE A PIPE IN THE PROCESS. ANY ONE HAVE A IDEA AS TO BEST WAY TO COMPLETE THE REMOVAL. THANKS.
| There are none. |
