| Posted by hj on April 04, 2002 at 23:15:45: | |
| In response to Re: Relocating PTrap | |
If you want to have a shower that does not drain properly and never will drain properly, install it using two traps. Otherwise take that one out and install a new one in the correct place. : Hello, : Q: Can I leave the existing Ptrap in place and add a new one (effectively having 2 in series) or do I have to remove the existing one, add an extention, then add the new one under the new shower drainage hole? : Thanks
| There are none. |
