| Posted by hj on April 04, 2002 at 23:11:59: | |
| In response to Re: Rough-In : Tight fit for installing toilet | |
If you want to spend a few hundred dollars for a toilet with a high tank, then you can modify the drop pipe to do it. It will be cheaper to break the floor and move the pipe to the proper point. : My basement cement floor rough-in for the toilet is barely 12" from the unfinished masonry wall : I want to install toilet AND also install finished section of wall there ; even a 10" stool will not fit , what with the finish wall space used :: CanI "REMOTE" the toilet tank vertically a few feet or more , something like the "olden-times" toilets are pictured ??
| There are none. |
