| Posted by hj on April 01, 2002 at 22:19:39: | |
| In response to Re: Kohler shower faucet reversed | |
You have to remove the entire unit and rotate the whole thing 180 degrees so the left hand stem becomes the right one and vice versa. You cannot just loosen the screws and twist it 180 degrees. : I recently had a Kohler shower R12007 - 4S - CP faucet installed. The water temperature is reversed - hot water comes on first. They tried turning the valve 180 degrees with no change. Any suggestions?
| There are none. |
