Re: Replacing bath with shower unit
Posted by hj on April 01, 2002 at 22:14:06:
In response to Re: Replacing bath with shower unit
You only have one. Break the floor and relocate the trap and riser to the new drain location. : Hello, : I recently yanked out a bath tub in my downstairs bathroom (concrete slab). I have a new 2-piece Lasco corner shower unit (neo type). The existing drain pipe through the slab is (what a surprise) not directly under the intended waste hole in the shower pan. The shower pan will have a 3/4" clearance if levelled correctly. What options do I have to couple the two together? : Thanks : Tony.
Replies to this post
There are none. |
