| Posted by Mario on April 01, 2002 at 15:25:49: | |
| In response to Re: Yellow Fiberglass | |
: : Hi, : : We're in a new manufactured home and have a fiberglass jacuzzi in master bath. I put a white foaming milkbath in the tub, without jets. The fiberglass which is white turned yellow. I've tried vinegar, soft scrub, Bartenders Helper, Bon Ami, etc. etc. Any idea's would be appreciated. Thank You : There is a product called Gel-glos that is made for fiberglas . It cleans the fiberglas and restores the finish. It should be available at a plumbing supply shop. "Do you have a high iron content in your water supply? Try using a liquid cleaner called "Wink". It works great on fixtures and clothes as well. |
| There are none. |
