Re: toilet bolt broken or floor wood bad?
Posted by hj on March 30, 2002 at 08:32:56:
In response to Re: toilet bolt broken or floor wood bad?
Saw the rusted bolt off so you can remove the toilet. Then you will have to see how the bolts are secured to the flange in order to know how to finish removing them.
: Hello...
: The toilet in my mobile home (1977 Cameron) was rocking so I checked the bolts, one was on tight (rusted, I think) the bolt on the other side is either broken, losened from the flange (if there is one) or the floor is rotted. I do not see any water on the floor, but I do hear something like air bubbles when you sit on the toilet.
: First question... How can I losen the rusted up bolt so I can remove the toilet?
: Second question... IF the other bolt is broken, how do I free up the piece that is stuck in the flange? (if there is one)
: Third question, If it's the floor, can I just put some wood over the small section where the toilet is and replace the ring, just for a temporary fix?
: Is there anything I can do for a temporary fix to stop it from rocking, until I can get a plumber and/or carpenter in here??
: Lee Ann
Replies to this post
