| Posted by Kelsey on March 28, 2002 at 22:20:03: | |
Should the plastic flange on the bottom of a KANT-LEAK wax ring fit down into the smallest ID of the bowl flange and act like a "funnel" or should it be the same size as the tail pipe on the bowl flange and sit on the recessed hub of the bowl flange? If it doesn't fit down in the tail pipe what keeps it from leaking? |
