Re: Uneven tile floor for toilet install.
Posted by Gary Swart on March 28, 2002 at 00:35:08:
In response to Re: Uneven tile floor for toilet install.
There are some excellent products to level floors before laying tile. It doesn't sound like you have to level a large area and it isn't very deep. I believe a product called "Floor Patch & Level by Jasco would work very well. It comes in at least 2 size containers, I think the 3 lb would be enough for you., It applies much like spackle on walls, but it is a floor filler and leveler. It applies with a trowel or large putty knife and makes a beautiful feather edge. From the container: "Easy Spread*Fast Set*Water Repellent* Ready to Use Fills: Cracks, seams, holes, joints, knotholes. Levels: Small areas of uneven flooring or counter tops of concrete or plywood for sheet vinyl, tile, or other type covering. I recently discovered this product and used it. Unbelievably simple to use and does exactly what it says it will do. Home Depot (et al) have it.
Replies to this post
There are none. |
