| Posted by edj on March 27, 2002 at 23:54:54: | |
| In response to Re: tub's cold water pipe leaks | |
: I need to replace or fix a leak. And don't know where to start. Its the cold water pipe (cheap moblie home piping) to the tub that is leaking. I tried to tighten this plastic (don't know what it is called) thing that holds the pipe together (I think) with no avial. : please help Sounds like you have cpvc piping which is usually glued together.You'll probably have to go to a plumbing supply store to find replacement pipe,fittings, and glue |
| There are none. |
