| Posted by hj on March 25, 2002 at 19:00:40: | |
| In response to Re: 2 inch toilet drain | |
if you want a lifetime of toilet troubles, usually after every flush, connect a toilet to that 2" drain pipe. A pump would take care of that problem but could create many others. You should only use a pump as a last resort, not if you have a sewer line available even if it is 14' further away. : Is it possible to use a 2" drain pipe for a toilet? I recently had a 7 foot x 18" cut put in my basement floor to add a bathroom. To my horror, the drain in the floor was only 2" in diameter. The 3 or 4" drain would have been 14 feet further away. Is it possible to use a air assisted toilet with this 2" drain? Would a sewerage pump ($400) be the only real answer?
