Re: Locate cast iron sewer pipes in basement
Posted by hj on March 25, 2002 at 18:57:04:
In response to Re: Locate cast iron sewer pipes in basement
Unless the metal detector is both powerful and sensitive, it will not likely detect the cast iron pipe at the depth it is normally installed under the floor. A professional locating service can tell you where it is.
: I'm planning on installing a 3/4 bath in my girlfriend's basement and was wondering if anybody has found a good tool to locate the 4" cast iron sewer lines. Does a metal detector work good enough to trust it? Just don't want to break out any more concrete than I have to. Thanks for the help!
Replies to this post
There are none.
