| Posted by edj on March 24, 2002 at 22:56:38: | |
| In response to Re: Copper Pipe Leaks | |
: No. The leaks may be caused by the circulating pump moving the water through the pipes too fast and eroding the copper tube. : : Our home was built in 1993 in central Calif. In the last two years we have had two pin holes show up in the pipe. They are not at fittings they are in the run of pipe. It is the hot water pipe with a circulating pump. : : Am wondering if there is a class action against copper pipe manufacturers for faulty pipe? I agree with hj.You may want to install a timer on the pump run it on peak demands only. |
