Re: Cast iron toilet sewer pipe/floor flange ID
Posted by hj on March 24, 2002 at 20:48:59:
In response to Re: Cast iron toilet sewer pipe/floor flange ID
If it is regular cast iron sewer pipe, then a cauld on flange should fit. There is also a clamp on cast iron flange that should fit.
: I have a cast iron sewer pipe that a toilet must use. I need to remount the toilet, which was leaking
: badly. I found out that there was no floor flange, and no flange I found to purchase will accomodate the
: 5 in. sewer OD. Will I have to change to pvc, a big job, or should I keep looking?
Replies to this post
There are none.
