Re: soldering a fitting next to another one
Posted by Gary Swart on March 24, 2002 at 10:40:35:
In response to Re: soldering a fitting next to another one
You won't melt the solder at that distance, solder will melt if you are connecting fitting together, but this won't cause the joint to leak as long as you flow the solder into the joints. If you have a valve that is very close to the area you are heating, wrap a wet rag on the pipe next to that fitting. That will be enough of a heat sink to protect the valve. Remember though, the pipes will still be hot enough to burn you.
Replies to this post
There are none.
