| Posted by oscar on March 24, 2002 at 09:31:42: | |
Hi, I need to tie into a copper water line but there's a joint about 12" away from the spot that I need to tie in , will the heat affect or melt away the soldering from that joint? 12" is the furthest I can go I would prefer to get closer as it will give me more room to work Please advise how close Can I solder the fitting to the existing joint? thanks |
| There are none. |
