| Posted by edj on March 22, 2002 at 00:27:05: | |
| In response to Re: Is it ok to use 3/4" fixture rough in with 1/2" supply lines for a shower? | |
: : : I am remodeling my home and have existing 1/2" water supply lines. The new Hansgrohe fixtures (Thermostatic regulater, volume control and diverter)that I just bought have 3/4" inlets and outlets. Is it ok to reduce down to 1/2" at each conection without causing any reduced pressure or volume? Also would I be better off just running 3/4" piping for the rest of the shower rough in after the first conection or does it matter? : : : Any help would be appreciated. : : : Mark : : : You should be ok with 1/2" since you'll only be using 1 outlet |
| There are none. |
