Re: Water Temperature Change
Posted by edj on March 21, 2002 at 22:18:34:
In response to Re: Water Temperature Change
: I am in the process of replumbing my house to remove Pb pipe and acetal fittings. My master bath is fed by 3/4' lines which split somewhere (I'm not into the walls yet) into 1/2 lines to two sinks, a toilet, a tub and a shower stall. When-ever someone is using the shower and another valve in the master bath is opened there is a sudden change in water temp in the shower. What could I change while I am replumbing to eliminate this problem?
Install a pressure balancing valve for your tub and shower.This maintains equal pressure for hot and cold regardless of water usage in the house
Replies to this post
There are none.
