Water pressure too high and Tile under toilets
Posted by Deborah on March 20, 2002 at 08:51:16:
Our water pressure is too high causing the water to blast all over the sink when the kids turn it on. Also have not been able to convince hubby to turn down shower to avoid $175.00 water bill. Is there a way to fix this? I have tried turning down supply on sinks, but most of them are stuck. I can replace them, but would rather not if there is another solution. Also, we are having tile installed in 3 baths thus will need 3 toilets uninstalled/installed. I am VERY handy, but have never done this. Would you please advise if it is a pretty clear cut job or if I should call the pro? AND would you recommend replacing with low flow toilets at that time?
