Re: poured shower floor drain
Posted by Gary Swart on March 19, 2002 at 22:39:37:
In response to Re: poured shower floor drain
Do the rough-in from the sewer line to the shower with 2" pipe. Use a welded (glued) pee trap with a short length of 2" pipe protruding above the floor. This will be trimmed when you install the shower. It should be obvious that the pee trap and especially the pipe going to the shower must be centered on the shower as there will be no adjustment later. Once everything is in place, proceed with packing fill, gravel and then mud.
Replies to this post
There are none. |
