: : my house is 1yr. old have press. red. valve and duel check valve on the water meter spread house just started making a foghorn and viberation noise on the copper water lines when I use the shower first thing in the morning only I put a thermal expansion tank on cold water line it helped a little then i reduced pressure on reducing valve it worked for everything except washing machine makes noise now when it fills up i also have less pressure now at faucets is what i tried right what else can i do how can i fix noise at washer
