| Posted by Bobby on March 15, 2002 at 13:25:45: | |
Im installing a basement toilet and am concerned that the PVC flange will crack when I screw it down to the concrete. I've haven't glued the flange in yet, but have tried it in the existing roughed in drain. The surrounding concrete isn't perfectly level and the drain sits off the concrete a slight bit in places (not much). Is there some kind of caulk or filler I can use to fill this void, so not to crack my flange once in place??? Thank you. |
