Re: Whats a good water heater
Posted by edj on March 14, 2002 at 23:40:07:
In response to Re: Whats a good water heater
: I want to replace the water heater in my third story attic, it's gas. What heater can I put there so as not to ever have to worry about it busting or leaking.
: What does glass lined mean, and what if the heater was damaged in shipping and the glass cracked (how would I know)
: What is a good tankless heater and would this be a better alternative, there are only two of us here with no kids, and 4 bathrooms, but only two with bathtubs.
Even the best water heater,tankless included have a tendency to fail eventually.There are pans specially made to fit under the tank to catch and drain the water from a failure.The outlet is big enough to handle full flow and it can be piped out of the house.Again I've seen top of the line water heaters leak after a short period of time and I've seen heaters that are 30 yrs old and still going strong so you should protect yourself regardless of what kind of tank you buy
Replies to this post
