Re: Replacing bath/shower fixtures when valve behind tile
Posted by hj on March 11, 2002 at 23:12:04:
In response to Re: Replacing bath/shower fixtures when valve behind tile
The answer to your question is directly related to the brand of faucet you now have. Give us the brand and we may have an inexpensive solution for you. : I am remodeling my bathroom and planned to replace everything except for the tub and the surrounding : tile. I plan to have the tub and tile resurfaced after I get the rest of the bathroom done. This is a guest : bath, so I want to keep the cost down. : I had planned to replaced the tub & shower fixtures, but after visiting a plumbing showroom : earlier today, I discovered that none of the new fixtures will fit the valve currently in place, and several : pieces of wall tile would need to be removed to access the valve to replace it. They are the common white : tile squares, so not difficult to find. : Question is, how difficult is this? : The person at the store told me that I would probably end up cracking a lot more tiles and loosening the : surrounding grout, and that if I don't plan to replace all of tile, I shouldn't consider replacing the valve. : Any opinions?
Replies to this post
There are none. |
