| Posted by More on March 11, 2002 at 21:53:53: | |
| In response to Re: Bathroom floor replacement old underlayment | |
You can pretty easily do the job yourself for less than half the price of as professional, if you are careful and conscientious. The old linoleum is glued down. A hair dryer, or rented heat gun will soften the glue enough to get a putty knife under the tiles, and lift them off, and also scrape away the majority of the old adhesive. Thirteen years is NOT an old floor. The subfloor should not be damaged, ripped torn or most important, WET ! Most tile and flooring supply houses sell new linoleum at about 2 dollars per square or less, but you should also look at the self applied single material flooring (such as Armstrong or Congoleum) It is soft. pliable, easy to clean, easily molded around pipes and fixtures, and long lasting. : In most cases they would want a smooth defect free : : We are trying to get a bid for a linoleum replacement for our bathroom. The only local company interested
| There are none. |
