Re: Slow drain through disposal
Posted by hj on March 11, 2002 at 08:07:49:
In response to Re: Slow drain through disposal
It could range from an obstructed baffle tee to a seriously corroded disposer. if it is the tee, unplug it. If it is the disposer replace it. If it is something between these two extremes you will have to determine it and also how to fix it.
: Water drains too slowly through my garbage disposal. When the disposal is on it works great; waste and water disappear in a hurry. When it is off, though, water drains slowly. When the dishwasher runs, the disposal sink fills up with outflow from the dishwasher and drains slowly. Solution?
Replies to this post
There are none.
