Re: leak from hot water supply valve to washing machine
Posted by Gary Swart on March 11, 2002 at 01:43:06:
In response to Re: leak from hot water supply valve to washing machine
Sorry for the screwed up posts above. Sally, it is pretty apparent that you have a problem that you have neither the knowledge or tools to fix. It isn't going to get better, in fact, it's likely to get worse. You'd better either find a friend with some skills in plumbing or hire a professional. This is a time when Murphy's Law will definitely work agains you. If that pipe lets go in the middle of the night, you'll not only have to pay an arm and leg for an emergency night service call, but there could be serious water damage to the house and you possessions.
Replies to this post
There are none. |
