| Posted by Gary Swart on March 08, 2002 at 18:03:58: | |
| In response to Re: main water line | |
It's likely the pipe is mostly corroded shut, so just replacing the line would help. However, it's also likely the meter is 5/8", so the value of the 1" pipe would be minimized. While you're doing it, consider a new 1" meter. $2500 is quite excessive. Look into doing the trench yourself and then shop for someone to do the pipe and meter. |
