Yes, certainly. Please describe what it isn't doing.Is the circuit breaker engaged, or tripped? Is the switch turned on and electricity flowing to the pump? Is the pump getting a "Start - Run" signal from the float switch? Does the sump pump hum and motor vibrate? Does water slosh around in the pipe and sound like it's being discharged? If so, look at the submersible pump posting just below for repair alternatives. If this is more than you can handle, post another question with more information, seeking more advice. : my sumpump is not pumping.can you help me? : thankyou
