Re: Pressure Assisted Toilets
Posted by edj on March 06, 2002 at 23:14:59:
In response to Re: Pressure Assisted Toilets
: Terry:
: I have a question concerning the 1.6 gpf using the Power Assisted toiletIf the toilet is using the force of the water to push the waste with 1.6 gallons of water or less would there be a problem with the lenght the waste had to go to the sewer line using less water? I have a 6" 300 ft. run sewer line with 1% fall. I am afraid that there will be no water push the waste the entire length of the pipe.
That is a legitimate concern but would take quite a lot to plug a 6" line and there should be enough gray water waste to keep it clear.
Replies to this post
There are none.
