Re: Toilet Flange on basement slab
Posted by Gary Swart on March 06, 2002 at 01:13:36:
In response to Re: Toilet Flange on basement slab
This is unbelievable! I just did exactly what you have to do this evening. I had to cut the 3" ABS below the surface of the floor. What I did was to get it close, then I took a band clamp and put it on so that the bottom was exactly the right height. Then I took a PVC cable pipe cutter and sawed the ABS off. It's not the very best cutter for ABS, but it worked. I had to take an additional 1/2" off because I can never measure right. To do that, I used my 4-1/2" grinder. Again, not a professional way to do it, but it worked just fine. Had to rasp the slag off, but no big deal. Flange fits perfectly.
Replies to this post
