Re: Pressure balancing valve
Posted by hj on March 05, 2002 at 23:26:14:
In response to Re: Pressure balancing valve
Without seeing the situation, anything is a guess, but a pressure balancing valve just prevents/minimizes temperature changes when water is used elsewhere in the house. If the hot water temperature itself is variable, which could be possible with a tankless water heater, then that is something the valve is not able to compensate for.
: We installed a new Enviro-Tech shower fitting with pressure balancing valve. Since installing we are unable to balance the water temperture, it is either too hot or too cold. We also installed a new tankless hot water system. Could this be our problem? The sink has both hot and cold water with no problems. Could it be the pressure balancing valve?
Replies to this post
There are none.
