Toilet Flange on basement slab
Posted by Kirk Maskalenko on March 05, 2002 at 22:09:15:
The rough-in centerline for the toilet is 11 1/2 inches from the wall. Should I use an offset flange to install the toilet? Will a 12 inch rough-in toilet fit?
How do I cut the drain pipe once the concrete is chipped out around the drain? Are inexpensive inside pipe cutters available?
Replies to this post
