| Posted by hj on March 04, 2002 at 21:50:21: | |
| In response to Re: RE: Primer and PVC Pipe | |
What kind of pipe is it and where is it. If it is a pressure line and it will be accessible in the future if it should come apart then you might want to take the chance, otherwise cut it apart and re-do the connection. : Hi all, Quick question, While priming and gluing a series of connections, I forgot to prime one connection, think the glue was getting to me! Anyway I didn't realize it until after I glued it in, am I OK without the primer on this one joint?
| There are none. |
