Re: garbage disposal leaking at the reset button
Posted by hj on March 04, 2002 at 07:46:09:
In response to Re: garbage disposal leaking at the reset button
Unless you have a lot of time or money, and/or the disposal is a very expensive one it is not worth repairing. By the time that happens the cutting plates are usually worn out also.
: My garbage disposal has starting leaking at the bottom, where the reset button is. Is there a seal that I need to replace? If so, do I simply take the disposal apart? Is it time to just get a new disposal? The one i've got is probably around 8 years old.
: Thanks.
: David
Replies to this post
There are none.
