| Posted by hj on March 03, 2002 at 14:33:56: | |
| In response to Re: Raising the hot water heating pipes in the basement | |
Since the system has been converted to a pump, and the old pipes are probably extremely oversized for a circulated system, you might be better off jsut installing a one pipe system with Monoflo tees. It will be a much smaller pipe system and should work as good or better than the existing one if it is installed properly. : I have a 100 year old house with a terrific old boiler that feeds the hot water radiators through pipes that are hanging below the joists in the basement. Originally, I presume that this was a gravity system, however there is a circlulating pump at the boiler now. I would like to raise these old pipes to the level of the the joists. I will have a plumber do the job. However, some say to never touch the old system, that the new pipes may not work as well. What are the problems that I might face with such a conversion? Is it ok to replace part of an old steel pipe system with new copper?
