Re: DELTA KITCHEN FAUCET
Posted by edj on February 26, 2002 at 22:49:12:
In response to Re: DELTA KITCHEN FAUCET
: I HAVE A PROBLEM WITH THE SPRAY ATTACHMENT ON A DELTA ,SINGLE HANDLE,STANDARD FAUCET. I CHECKED THE LINE COMING FROM THE FAUCET AND IT IS FREE [CLEAN] I JUST DON'T HAVE ANY PRESSURE. WHEN I TRY TO USE THE SPRAYER , VERY LITTLE WATER COMES THROUGH [ VERY LITTLE ]. THE HOT AND COLD WATER , COMING THROUGH THE FAUCET IS NOT A PROBLEM. I EVEN USED COMPRESSED AIR TO CLEAN OUT THE TUBING , WITH NO LUCK.
: DOES ANY ONE HAVE A SUGGESTION?
: THANKS
: MIKE
When you remove the spout there will be a diverter in the brass body,Popout the divertor and clean or replace.
Replies to this post
There are none.
