Re: shower base drain
Posted by Terry Love on February 25, 2002 at 13:21:11:
In response to Re: shower base drain
: I am installing a rectangular shower base. It fits where the tub use to go. There is a larger opening for the drain on the shower base. So I will have to do a few modifications. I have a drain that adapts onto the shower base. The shower drain is called a quick caulking on the inside is a rubber seal that is ridged. It looks as if this is pressed onto a proper sized pipe. To form a seal. Do you recommend this.
The rubber seals work fine for the drain. They will fit 2" pipe. The tub drain was 1.5" so some change in size needs to take place. The local inspector will let you know if you can use the existing 1.5 wasteline for the shower.
Replies to this post
There are none.
