shower base drain
Posted by Gordie McNeil on February 24, 2002 at 15:28:08:
I am installing a rectangular shower base. It fits where the tub use to go. There is a larger opening for the drain on the shower base. So I will have to do a few modifications. I have a drain that adapts onto the shower base. The shower drain is called a quick caulking on the inside is a rubber seal that is ridged. It looks as if this is pressed onto a proper sized pipe. To form a seal. Do you recommend this.
Replies to this post
