Re: leaking hot water overflow pipe
Posted by Kim on February 23, 2002 at 20:07:53:
In response to Re: leaking hot water overflow pipe
I had this problem a couple of months ago. It's amazing how much hot water you can waste. Anyway, I turned off the water and then removed the hot water tap. It turned out the little rubber 'O' washer (I'm not sure what it's called) had shifted and was not sitting correctly. I put it back in place and put the tap back on. This solved the problem pretty good but not perfectly. I then replaced the rubber washer with a brand new one and voila! problem fixed.
Replies to this post
There are none. |
