| Posted by edj on February 23, 2002 at 19:37:24: | |
| In response to Re: Button-style stopper & clog | |
: Our bathtub has finally quit draining after eating my long hair for three years. : In our old house, we just snaked it every six months, and it was fine. However, we cannot figure out how to get this stopper out to properly snake the line. : It is in the drain, and you push it down to close the drain and fill the tub; and vice versa, pull it up to drain. : We have tried several drain cleaners to no avail, plus, is it a good idea to use caustic materials like that with a septic? : Any help appreciated. there are two types of button drains I can think of. One you turn the whole piece counterclockwise to unscrew it from strainer. The other has a cap over the screw. The piece that you pull up on actually unscrews leaving you a brass stem which is attached to the strainer. This brass piece usually has a slot for a flat blade screw driver. |
| There are none. |
