| Posted by Paul Wolpert on February 20, 2002 at 09:24:48: | |
| In response to Re: Venting Bath Room Fan | |
I always vent bathrooms and kitchens through the roof where possible. If installed and sealed properly it should never give you any problems. When you try to vent via the soffit the warm moist air wants to travel back up thus the moisture you are seeing above where you are venting. It is also possible, if you have an actual built in discharge vent in the soffit that there is a hole in your vent line or it has become unconnected, or it may be close to an intake vent. If you just layed the vent pipe close to a soffit intake vent you will get what you have. I also like to insulate the vent pipe to reduce the condensation inside the pipe. Hope this helps. Paul : : Hello: I live in Canada where we have a fair amount of snow and it is a little cool this time of year. : : I also checked the outside wall near the eves, where my fan is vented out the soffits, there is an ice built there. Now maybe some of my attic moister or maybe all is due to the ice built up and my fan being vented through the soffits. : : If so where can i better vent my fan??? Also when I was in the attic there was not much air movement, so therefore i think i require more air flow. What can and should I do to provide more air flow??? : : Thankyou, please reply soonest, need to get this problem fix to minimize the damage. : :
| There are none. |
