| Posted by james cratt on February 19, 2002 at 00:45:00: | |
Water way too HOT!! Trips high limit switch. Reset & I checked upper thermostat w/ volt meter (240 volts) at same time lower thermostat reads 120 volts !!!!??? When upper thermostat is off lower thermostat reads 240 volts. I thought when upper thermostat is ON (240 volts) that lower thermostat is OFF!!(0.0 volts). When water heater is on (upper thermostat 240 volts)& (lower thermostat 120 volts), Wire (#10-3w/gd & 30 amp. breaker)to water heater becomes VERY warm, & power co. meter is flying @ 90+ mph. I replaced upper thermostat w/ a new one. Same thing! Then replaced lower thermostat w/ a new one. Still the same thing!!! It is a RELIANCE ELECTRIC 501 w/two 4500 watt heating elements, from local TRUE VALUE HDWE. ANY & ALL HELP WOULD BE GREATLY APPRECIATED!!! SINCERELY JAMES CRATT |
