Re: setting pressure regulating valve
Posted by harry on February 18, 2002 at 14:40:35:
In response to Re: setting pressure regulating valve
: I cannot seem to get the cut off pressure above 42psi. I have not tightened the cut off pressure nut all the way down, but about 2/3 of the way. Does this suggest that the pump may not be capable for some reason of exceeding the 42 psi? Or, should I try to tighten it more? The air pressure in the tank is at 28 psi without any water pressure. I should have put "...regulating switch" rather than "valve" in the subject line. H
Replies to this post
There are none. |
