| Posted by hj on February 16, 2002 at 08:20:01: | |
| In response to Re: converting a sloan flushmate 1.6 gal (pressure assist) | |
You would need a new tank and you would have to check the catalog to see if the same numbered bowl is used with both the gravity and pressure units. If not then the pressure bowl is designed for the greater velocity of the pressure flush and will not work with a gravity tank. : i just bought a gerber toilet with the sloan flushmate tank."1.6 gallon" while it works very well and very loud, can this unit be converted to a standard gravity flush with the appropiate tank hardware?
