Re: Tub and shower stall removal
Posted by DDR on February 15, 2002 at 14:31:18:
In response to Re: Tub and shower stall removal
: : Is there a special tool needed to separate the tub and drain? I need to remove my one piece fiberglass unit and replace it but not sure how to separate the tub from the drain. I would recommend a tool that removes the tub from the drain. I have accidentally snapped off the trap grid one too many times by using pliers and a screw driver. The tool is only about $10 and will save you much time and grief in the long run.
Replies to this post
There are none. |
