Thanks, edj. I see your point about the optimal way of doing it: new flange and get new concrete in position to anchor a new flange down.I am also interested in your "band-aid" approach. The current flange isn't in that bad of shape except for that slight crack in the PVC. I figure if I could glue that crack then the flange would be solid again -- or at least solid enough. : : I have an offset toilet flange made of PVC with a : : blue painted steel flange ring. I have slightly : : cracked the PVC near the metal flange in an attempt to : : cure a rocking toilet. This was done by tightening : : the nut down too much.
: : I tried a flange replacement that slips over the whole : : original flange and will bolt to the concrete just fine, : : but the toilet won't fit over the new replacement : : flange. : : I assume the whole original flange can't be replaced : : right? The PVC is glued to the original discharge pipe. : : I assume that once PVC is glued, it's glued. : : Can I try to glue the crack? Could I neatly cut the : : top part of the PVC flange with a Dremel tool? Then : : clean, primer, and glue the PVC back? Would it hold? : : Then metal ring is fine. Just when I snug the nut down : : the crack in the PVC near the flange opens up, once : : again leading to a rocking toilet. : : Note that the original flange is not bolted to the : : slab foundation, just the PVC pipe. Also note that : : any attempt to bolt the flange down won't work as to : : get the offset, quite a bit of foundation was chipped : : away -- enough that there isn't much material under : : the metal flange lip. : : Unless you can secure the flange solidly I don't think you'll be able to solve your rocking toilet problem. Is it possible to pour new concrete around the flange.What I would do myself would be to break the floor around the flange,dig out enough dirt to undermine the concrete. I would put toggle bolts in the holes of the flange,screw the wings on the bolts,the bolts will provide a good solid anchor for the flange. Mix the concrete and leave it rather runny,fill the entire hole and allow it to set properly. Being a plumber I would cut the pvc from the inside of the pipe with a cutting wheel, glue a coupling and new flange on.I could tell you how I would "bandaid" the old flange if you're interested.
