| Posted by hj on February 12, 2002 at 21:57:55: | |
| In response to Re: Line Clear But Toilet Overflows | |
If that is the only one with the problem, then the things he did were probably not necessary. Did he auger the toilet or take it up and check it? That would be the first place to check when only one toilet has a problem flushing. : Toilet overflowed. Plumber cleared line and vent pipes. Toilet overflowed again days later. Plumber snaked line again and said it was clear. All other toilets, tubs, and sinks flush and drain fine. : In fact, most of the time the overflowing toilet flushes great. Plumber claims the problem is the cheap off brand made in Mexico Home Depot toilet I installed in 1997. : I thought a toilet was a toilet and am perplexed as to why this admittedly inexpensive off brand overflows so easily? : The offending pottie is a ground floor unit located within 5 yards of the overflow pipe in my front yard. : Want to know if I should purchase a better toilet or have another plumber give a second opinion?
| There are none. |
