| Posted by edj on February 12, 2002 at 20:16:22: | |
| In response to Re: Hot water has no pressure throughout the house. | |
: : how old is the house? Galvanized or copper waterlines? : The house is about 50 years old. Galvanized steel water lines tend to rust after time. If you've recently had some work done some of the rust may have moved up and plugged the hot line. If all the hot water is effected in the house I would suspect that it is somewhere above the water tank before the first branch.You may need your plumber to attempt to flush,clean or replace the lines |
